Water doesn't render correctly
Recently with one of the updates to Enscape water has not been rendering correctly for me. Any material named water basically becomes a mirror, instead of the old version where Enscape would render water beautifully. I will upload a rough render of the issue i have been having. Has anyone else been having this problem as well? Thank you in advance for any solutions!
One issue could be that it is a single plane with the normal pointing downwards. Is that possible? Does it still occur on a normal box?
I reversed the plane of the pool and it works perfectly now! Thank you so much!
@Khagan25 Great to hear that, thanks for the feedback.
This bug is fixed in v2.2.1. You now do not need to flip normals anymore.
Great work! Thank you very much.
I’m having this problem with Enscape 2.9 and the Enscape Preview 3.0.0 (Preview 3 + 35113), using Revit 2018.3. The water in this bath (see attached) used to show waves, now it’s a flat mirror. I’ve checked the material assignement, tried changing the water type, increasing the wave height… It reacts to a change of colour, but never shows waves.
Could you help?
Thank you,
Jf
Please go into the Atmosphere tab of our Visual Settings and a bit of “Wind” “Intensity” to the scene. If you don’t have any wind, you will also not see any waves. Let me know if that doesn’t help! :slight_smile:
Hello, some of my colleagues and I are experiencing strange behavior with regards to water in Enscape via Revit.
We have created a test file whereby some users can see the water in Enscape as expected (waves, reflections etc.) whereas myself and other users see flat color. The model is the same for all parties, we also have the same graphics card (Nvidia GP4000 installed).
First image shows the non-working render in Enscape
The second shows the same model working albeit on a different machine in Enscape.
The last couple of images show the settings for the water material in Revit.
PLEASE HELP!
Hi @NathanielRackham
Welcome to our forum.
Can you also confirm all parties have the same Visual Settings applied.
For example, do they all have the same Rendering Quality and Wind Intensity applied?
Hi Rick, we solved the issue internally - in Revit the Enscape material selection was set to ‘graphics’ as apposed to ‘appearance’.
Case closed
