water feature / waterfall
For a new project I need to make a water feature something like this:
has anyone done something like that? any tips? anyone fancy making one for me in phoenix or realflow? (I’ll pay!)
peter
just did… Photoshop brush :slight_smile:
3d please!
Kind of a job for blob mesh, pflow, maybe some curved sheet geometry with a stretched noise map in a displace slot, some bumps and what not.
tried something like that years ago:
just thought that in this day and age, fluid simulation software must be able to cope with a simple water feature filling a shallow pool pretty easily? am i misguided?
to be clear, I want something that looks AWESOME, not just good, and am willing to pay someone else to do it :slight_smile:
Ah okay. Yeah it’s pretty easy to do, I’d go with naiad, krakatoa and frost. You’d end up with a prt file for your splashy bit and a vrmesh for your pool.
Someone at work pulled it off using realflow (and it looks remarkably like the example you’ve posted) but it was hair-pulling stuff from the looks of it. He spent days doing it and the simulations were at a snail’s pace. I’ve never used fluid-sims before but realflow looked painful.
yeah i guess it would take me days as well if i bought all the right tools..
Film it!
This is a quick proof of concept I did a while back - we then spent a couple days with a hosepipe and a black board filming new ones. after collecting a shitload of thin strands I took them into fusion and made a 4k wide, looping animated waterfall. On decent curved geometry, animated noise to shake it up & the map in the opacity and displacement it came out looking great.
also plan to film water splashing into a pool from above to do the same for a displacement map on the water surface but we didnt need it for that job.
I wonder if you could use those techniques along with this script to get something to work for the way it breaks apart as it falls.
thats a nice looking script :slight_smile:
id just use geometry and model it
ok next question.. anyone got tips on water material settings for speeding up renders of alembic particles loaded using vrayproxy???
I would go with a simple plane, little bit of modelling, bit of noise and a good shader.. for the upper part.. a scatter for the bottom part, and getting them together. Not a realflow or phoenix solution, but fast n clean! ( of course if this is a still image)
Peter is there any chance of trying the horrible thing of importing the mesh into your scene? Since vray proxy is more of a get out of jail card for high memory scenes and not the best choice for performance can you bring a mesh in?
i’ll post an image soon John, pretty happy with how vray is dealing with abc files actually! was more just the material i was interested in optimizing (turning off reflections, other ways of optimizing speed like that)
I’ve never used krakatoa or anything like that, so not familiar with materials for foam/spray for example
ignore the quality of the simulation, it is looking much much better in a recent test but this is an old one for testing purposes. I’m just wondering what sort of material to give this since I have no experience whatsoever with rendering particles.
I saw in 3.00.06 there is an option to render vrmesh particles as points OR spheres, and also a new vraypointparticlemtl . A quick test attached with a basic grey material. There are very limited options on the vraypointparticlemtl shader.., will there be additions or am i just not understanding how to use it?
if i turn on reflections and refractions the render time goes crazy on spheres mode (several hours), but on points mode its still really quick:
I’m guessing i would need normals info stored in the proxy file to have more control over how the material looks is that right?
Peter,
I am just finishing up a massive job, but I reckon phoenix would do a nice job of this so I will have a play with a few things and report back
Hi Chris, i’m just looking for ideas on the materials.. all the sim work is done (and looks pretty amazing - because someone else did it :wink: )
