anyone could give me settings to make some nice water for a pool like this one below :
coz even when i played with the fog color, i only get a very dark blue texture
thx for those who can help me ! i really need it…
make me some nice blueish pool transparent reflective water !!!
Thx people
PS: i already search on the forum but i didn’t find anything that is satisfying me, i tried the Vlado settings for water but i can get it to be with a nice blueish color like the picture above !!!
See the attached file. you only need to add caustics to make it complete.
make sure your water is bigger than your pool if you don’t you get intersecting faces wich causes wrong reflections.
this is very impressive render
I am very very new in v-ray.
I try to do a similar scene and get test renders.. though I use the same material you have posted, I can never get similar renders…
would you mind telling your environment settings and render settings?
thanks in advance
My environment settings are nothing fancy, you just need al lot of stuff for the water to reflect and a nice environment image (preferably set to spherical).
Erik, are you mapping this material to a simple plane object? Does it have a ripple or noise modifier applied to it? How many segments does it need? I have played around with all of these settings and have gotten some cool results, though nothing as striking as your swimming pool. Are the parameters in the material itself that will make it look more rippled?
for this image i faked my caustics and bottom of the pool. just used a mixture of water map and noise map for the ripples and like everyone said. the key is to have something to reflect or even refract. the caustics on the bottom of the pool are just textures
I never realized that a simple scene like this could raise so many questions. I am posting my scene here, i stripped it of everything that has a copyright and replaced the background image, the camera position and the light direction and setup remain the same as the above picture.
If you hit render your scene sholud look like this. (rendertime 2:40 min. on a P4 2Ghz 1Gb ram)
and the scene, you can change the intensity of the blue color by playing with the fog multiplier and changing the backgorund image.
If you can post your scene if you get what your looking for, i would like to see how you put my material to use.
thank you very much for the files it really helped me a lot…
I have one question: water element was a editable mesh so are there any rpiple or wave modifiers?-I saw many segments…
and still I cannot get the dimilar effect on my own model - there are no ripple or wave modifiers in my one.
The model is indeed a mesh, a solid mesh gives better refraction. But it has so many faces because it is imported geometry from autocad. There are no modifiers used, just the bump map to make the waves.
OK, I know this is a bit off topic, but i couldn’t stop noticing ur grass texture (especially right next to the paver)… Could we sample your that secret as well… That subtle displacement makes it so unequal… sooo real…
Its a material made with maps i found on this forum so don’t be offended if you see a material that was made by one of you. This forum is a great place to find tips and resources and i just made a good material a bit better.
