looking at a couple of recent renders, it would be really cool if you could see the reflected moving sunlight on vertical surfaces that touch water (like you would see on the sides of boats, under bridges or the edges of a swimming pool)
I agree - you guys are awesome: The new update to water with the latest release has given some cool additional options on how the surface is displayed and a real sense of depth too
… I understand that it’s still a preview release but …
The colour of the water is not linked to the colour of the material in the native application
The colour set in the Enscape material window is really washed out for shallow volumes - still can’t use it for red wine (it’s even hard to get a nice yellow for ‘white wine’ since it seems to add blue to the mix and give a green tint,)
The opacity has no effect.
(I’m not sure how I feel about the intersecting edges of a water texture and it’s container fading to nothing - it is a fantastic solution to obscure the fact that the edges don’t move with the waves and is much better than the static line that breaks realism, but…)
…and some more wishlist items…
To improve the washed out appearance in small/shallow volumes I think that there should be a user adjusted variable for the scale of the ‘fade out depth’; how close to the surface you see full colour saturation.
I would like to see the opacity work like a “Fog”; geometry seen through the surface fades and becomes more obscure the further it is from the surface. 100% opaque/black would not let you see anything through the liquid. 50%/grey would be ocean depths. 0%/white would be crystal clear waters.
I remember that water used to look like it cast some of the cool underwater light caustics; it would be nice to project these onto surfaces that are hit by light passing through a water plane. On a similar note ‘light rays’ from the surface go hand-in-hand with caustics and would be really amazing, but for the once in a blue-moon use I can’t imagine they would be worth development time.
I don’t know how, but it would be really cool if, when Enscape found two ‘water’ textures next to each other it blended the settings between the two.
(Just to repeat the other things noted in the first post that have not yet been implemented: )
Edge refraction - slider for the amount of convex/concave bend at the edge of a water texture; in a glass bend one way, puddle spill bend the other. {This would also add a line to the join between an intersecting water plane and it’s container … which would have to move with the waves or break the realism}
Special animation: Rain - Set size and density for random concentric rings on the surface of water)
Thanks for your feedback, @Gadget_1 . So far, the water is only designed to work on more or less horizontal surfaces (ocean, pool, rivers). It’s not designed to be used in bottles. I recommend using a traditional alpha surface for water which is not an open surface.
Currently, a white water color describes a clear water. Naturally, even “crystal clear” water absorbs colors which makes it look cyan. On the one hand, Enscape does not allow to create a liquid other than water, on the other hand it’s easy to match the real world’s water absorption parameters by using something close to white.
I was trying to use it in glasses rather than bottles;
if it’s a glass of water the refraction works well and does actually look like a glass of water (a little bit of strangeness with straight edges going around a curve, but close enough.) if it’s a glass of wine it looks like weak dilute squash.
If I use glass for the liquid I then have the problems associated with glass looking through glass looking through glass (etc) {BTW still annoying that glass doesn’t throw shadows: the bottle isn’t floating, it’s just that only the label and top are casting a shadow.}
Hello, can I please request to add this cool functionality to modify the water parameters (.e.g water color, wave height …), also in the other plugins especially Rhino?
I am 110% behind having a seascape horizon/skybox available from the preset drop-down.
The underwater caustics have been applied but only work looking through the surface and seem to work inverse to reality: the lighter mesh pattern does not lighten the ‘underwater’ surface, it just darkens the patches in-between.
It also remains in the same place as the sunlight moves, making it look even more like it’s on the surface rather than under the water (and just vanishes abruptly when the sun has dipped over the horizon). The caustic pattern seems to be mapped (not quite) vertically rather than tangent to the sun’s position.
You also have to be careful that both sides of a water plane are transparent (or filled with the same water) or you will get no shadows cast by the sun onto your underwater geometry.
(If light passing through transparent materials was tinted/lightened according to the settings then it would add massively to the realism of water.)
Water acts like a lens here, it takes from some areas (darks) and puts it onto others.
Enscape does not support the camera being under water since often times, the water volume is not enclosed. Mostly it’s just a plane.
That’s because water usually has no tint, all real world “waters” are completely transparent when sufficiently thin. A tint would still be there after 1mm. The color you see on seas & oceans is created by the water’s absorption which in turn can be specified in Enscape.
I understand that, however I think that it would both look better from looking through the surface and it would allow the viewer to ‘explore’ underwater. (and allow for things like viewing windows in a pool, fish tanks, glass bottom boats, …)
Yes, but we want things to look realistic without having to model everything as it would be in reality: The ideal would be to have everything look as natural as possible (given what was modelled), but then to use “artistic licence” and cheat so that we can add a specific tint to make it look how we want (… which may not be the same thing as looking realistic.)
In this image all the sides of the pool have water material assigned to both the front face and the back face, which led to having blue sides on the left and right.
Here i changed the back faces of both the left and right sides to sketchup default material instead of water. That resulted to having opaque white sides.
So i was wondering if anyone knows a possible workaround or a certain technique that could fix that problem and make it look more realistic …
I also faced another glitch with the water material when i simply moved the edge of this pool a bit to the left, It suddenly became very reflective. Any ideas why??
@Gadget_1 Thank you for your time and effort … But i am more interested in the water/water or water/glass workflow because they are transparent. Unlike the water/default that turns the sides opaque, which is not physically correct… I am trying to reach a workflow that is physically correct and shows how water would behave in reality. So your demonstration actually proves that my concern is not resolved yet.
