I’m trying to make an effective water material. But I have no idea how to do it. Anyone have any suggestions?
Re: Water
a clear glass material (which you can import it by right mouse clicking to scene materials title in material editor and browse) will nearly do the same effect. but you need to change the index of Refraction (IoR) value, this value for water is
Water (gas) 1.000261
Water 100’C 1.31819
Water 20’C 1.33335
Water 35’C (Room temp) 1.33157
but this may be not the thing you want. is your water a sea, pool water, water drop, a glass of water… for sea you additionally need a displacement map where you can find it at micha’s gallery (i know because i asked that to him
and he posted the map thanks again from here Micha) you may use same map for a pool water i guess but less displacement value. water drop needs no dispacement. and for water in a glass there is vray manual that may help you further about vray for rhino.
http://asgvis.com/index.php?option=com_remository&Itemid=47&func=select&id=31
