When rendering, each simulator will produce its own mesh, so when using a refractive material, there could be visible seams between the different Simulators. In this case the overlapping liquid produces the seam and some of the foam particles happen to be between the two meshes. To avoid that overlapping I’ve changed the height of the second simulator. That way more of the particles from the first simulator could be seen in the render.
For even better results you may consider to change the camera’s position, so the point of overlapping is not so visible in the render.
When creating cascade setups the Liquid simulators could be oriented in any way and can have different resolution, but to get the best results make sure that the Cell Size in the Grid rollout in all of them is equal. Waterfall_Cascade.zip (641 KB)
Thanks @Svetlin.Nikolov Will you post an update in here when there is something more to add to this. I’ll put aside this for now and await your update. Thanks for looking at this.
We’ve checked and the problem really appears to happen because of the two overlapping meshes. The suggestions from my previous post will help you to continue working on your project.
@slavina.nikolova One last question, grid sizing when cascading into different sized grids. Is it a matter of eyeballing the cell size indicator on the grids to know what cell size to make each grid in the cascade or is there a trick to getting a consistent particle size?
The Grid Size and the Total Cells count can be different, but in order to keep the particle size consistent make sure that the Cell Size is equal between the three simulators. This way the voxels for each simulator will be the same size and the particles travelling through the cascading simulators should looks the same.
Yup, especially if you have a lot of Splash particles, their sizes come directly from the simulation voxel size, so you could see noticeable differences if Splashes are a dominant part of the simulation. You could probably scale the larger or smaller ones in the Particle Shader using the size multiplier option, but this would be a render-time only hack, while the particles will still interact with one another with their real sizes during simulation…
Just realised something.. wetmaps on a cascading shot when the same geo cross both grids.. can have two materials assigned to a mesh - so the phoenix text picks up the wetmap from both?!
Ah, negative - the particle texture just outputs a black and white map, which can be used as a mask for blending between two materials, so if you have more than just a single pair of wet/dry materials, you can have one blend material per each pair, and just one particle texture plugged as a mask in each blend mtl. This should apply even if you have just a single simulator, but with many different materials in it as well.
