Hi everyone, I am new to VRscans and signed up for the trial. After about 5 minutes I’m already convinced.
However, I am having issues with watermarks on the render slave. Is this because of the limitations of the trial, or did I not set this up correctly. Thanks Chaosgroup!
Ah I just noticed that you need render node licenses as well. Thanks anyways!
Yes, the VRScans render node licenses should match the number of V-Ray render node licenses. If they are less the nodes that don’t have a VRSCans render node license will render with watermarks.
Thanks Ivan, I just bought the full version and a few render node licenses. These scans are amazing. Thanks!
