Worth a try. I have done just that. I had lowered the quality a little bit, plus the camera got real close to it. Specifically, the camera was inside a bunch of bubbles.
If that storage quality really is the number of bits (anyone confirm or deny?) then the default of 14 would give you 16,384 positions in each dimension (assuming it’s stored as an integer). This would only be a big deal with a bunch of cells, especially in one or two dimensions only (because three would likely be so huge you couldn’t/ wouldn’t simulate it at that resolution). Also, having the camera close could exacerbate things.
Apparently the storage quality also applies to particles, which is where I was really noticing it.
I could be totally wrong here, and this certainly may not be your issue. Assuming I am right each increase by one of the storage quality will double the number of positions, and increase space on disk and load time (Roughly) linearly.
Hehe, indeed, it IS the number of bits for most of the particle and grid channels - for some of them the meaning is different. And also yes - this means that particles could form lines when the quality is low: https://docs.chaosgroup.com/display/…ssionartifacts
Thanks for confirming this. In some tests I believe I saw results that indicated that the data was quantized at each frame and the next frame simulated would use the quantized days as the starting point.
I think I know why it is done this way (because you could never resume accurately). Part of me would like to simulate at the higher accuracy and then just store the quantized data art the lower bit depth.
This would be like doing all your color corrections in 16bit and then saving your output image as 8bit. Better results than converting to 8bit after each color adjustment.
Willie you certainly would get different results if you stopped and resumed would this not reduce the particles forming lines in the sim? Sorry, just thinking out loud here.
Oh, the simulation does not read back the compressed caches. The state of the solver remains in RAM with no quality changes. Only if you choose to Restore a simulation from cache after you’ve stopped it or even closed the host app, will the solver be initialized with the lower quality data. But also - the default compression quality is chosen as a good balance between size and quality, and we very rarely see scenes where 14 is bad (to put it more specifically - less than once a year).
I wouldn’t say I have ever seen 14 look bad. I would say I have seen higher numbers like 16 or 18 look a tiny bit better. It is all very scene dependent of course.
Oh wow! ahuumm i just turned storage quality to 20… now to see it’s tenfold in size! hui! With 14 it was around 300mb, with 20 is about 3-4gb, so be aware of that! i mean per frame
@Joelaff i wasn’t able to check if there’s a difference because of storage quality to be honest. I found a few other minor quirks so i’m running a new sim now with quality set to 16.
But the more i test, the more prominet it is, that in that special setup here, droplet surfing may cause the strange mesh movement. As i say it’s a special scene where i push things to extremes. So maybe it’s because normally the surfing is a vertikal thing in terms of splash is coming from above. And here when the wave staerts to crash it becomes more of a horizontal move because of the speec etc.. Don’t know if that makes sense, just loud thinking
Morning @Svetlin.Nikolov thanks for the offer!
Talking bout quirks, i right now stumbled over something else, i’m not sure i understand it. Please have a look at the attached pics.
First pic what you see is the complete scenery. As you can see in normal mesh mode all looks fine. Beach and rocks are fine solid objects and are blocked out correctly.
When i want to later on render that in ocean mode i just realized something strange is happening.
When changing to cap mesh mode as you can see in the second pic. There’s is that part of fluid in the beach. So wouldn’t see it anyway right but when changing to cean mode it seems it wants to connect somehow and creates those strange artifacts at the borders down to the ground. Is this normal behavior and i just oversee in the past or is there somehting completely screwed up in my scene? Maybe i should send it over hihi
I’d guess it has to do with Fill Up for Ocean and Clear Inside - check the info on Fill Up For Ocean here - there also is an example linked further down the page: https://docs.chaosgroup.com/display/…iquid+Dynamics
ah ok! that’s a direction at least, cool. But reading the docs again, to get rid of it, what can i do? Should i set the beach and rocks to NOT “clear inside” the
Yay! Indeed, in FLIP simulations you don’t need Clear Inside if the geometry is Solid - particles can’t get inside and if they somehow do, they will die anyway. Unlike grid fire/smoke simulations where Solid and Clear Inside can be combined.
Hi @Svetlin.Nikolov and all of the rest still following this thread.
First off, thanks for posting it in the facebook group! Awesome svetlin! The feedback is very nice to read
And here is my latest status regarding the breaking ocean waves setup.
I kinda like it already how it comes out, some things are cooler then i expected but some minor quirks are still there.
In general i would love to here some feedback and tips to get the last 5 percent out of it!
Here’s a clay render and hopefully you see what i see:
441959751
There’s a few things to observe where at some point in time and areas, the fluid develops some kind of its own behavior:
General remarks on the scene:
The raw mesh ( not smoothed in any way) in that areas looks very bumpy whereas in other areas (flat surface between the waves or when the wavfe is coming down) looks totally fine and smooth.
My cheat to combine the grid somehow with the ocean in that case is using only input channel smoothing, because meshsmooth and use of particles in smooth is causing artifacts at the borders.
I also have to take my verdict about the droplet surfing back. I thought problems at the end of the shot i.e. where caused by the surfing but it’s not causing any problems on the mesh at all.
1. when the wave starts to pile up and getting higher (first 10 seconds) the top of the wave starts to get some unstable boiling surface. That is getting worse when the crest starts to break, to closer to the camera the worse.
Interesting is that facetting which occurs on the mesh. Displacment, Meshsmooth and Input smooth could not get rid of it. Seems to be a motion blur thing, because in the viewport it kind of looks fine but camera motionblur seems to have some problems on it.
I did run a test with spf 4 but it seems to do no improvement on that one.
2. In the end when the camera stops and the wave is coming towards us. That part of fluid surface in front of the wave and movement looks like a bit of boiling to me, isn’t it strange mesh behavior here? How the wave moves forward?
Could that be related to older discussions about the beach wave setup and bloing ground etc.? The water here becomes very shallow then because it’s close to the beach here.
Hope that was understandable and looking forward to your answers!
Have a good start into the week folks!
Hey, I don’t have answers for any of these off the top of my head - they should not happen, but if you can send a setup that breaks here for us, we can check if these are bugs and fix them or make sure they don’t happen otherwise.
Good morning @Svetlin.Nikolov ,
you have no clue, hihi yeah that’s even more interesting
I would love to have a different pair of eyes looking at it. As i mentioned earlier, it could be many things as it is a test scene where at some places i pretty much tortured the values i.e. in the oceantex or having two waveforces etc. etc.
But maybe it’s a totally different thing which causes trouble as for example simple settings like the clear inside stuff.
Really looking forward what you discover hitting the sim button at your place.
Just send you the scene right now @ support
cool! @georgi.zhekov thx for joining in!
i have to repeat it`s a private project for testing purpose, so no client pressure involved in any way.
Nonetheless i think it’s a interesting attemp with the whole crashing wave thing.
As i’m fiddling with the scene here too i will also keep sharing my enlightments if there are any
Update:
i collapsed the collider objects finally as there were some fdd and stuff on it, and maybe more important, i also xresetted the collider objects (ground and rocks)
seems to give a different result, looks a bit cleaner at the ground, seems to clean out some stuff at the bottom of the beach and let’s see if it influences forces behavior then also.
As i’m off to berlin from tomorrow till sunday i will go for the brutal approach now with fine grid (80mio fluid particles) and 3 spf.
Also installed a new scratch ssd for faster writing and reading of cachefiles.
Let’s see :twisted:
