Waves and loss of hair help anyone
Im trying to create waves similar to what you see here. Non of the processes that are covered in Dreamscape or any other thing Ive seen including max wave or ripple seem to be able to produce this well spaced wave pattern with distinct acute angled wave faces. Im not so worried about the shore break since Im going to try and miss anthing actually breaking in the animation. Any ideas anyone ???
Maybe make a displacement map with lines where you want the displacement, then animate the UVmap in the direction you want the waves to travel?
Heres a quick and dirty example. Take a look at it and you should be able to see my approach. There is a box that is hidden which is working with the volume select mod which links the selection to a dummy object through a linked x-form mod. The dummy controls the shape of the wave face…the box object controls the amount of the wave that gets selected.
Keep in mind that this is only conceptual and not to scale…let me know if you need any more clarification.
http://www.dwayneellis.com/misc/other/IncomingWaves01.max
http://www.dwayneellis.com/misc/other/IncomingWaves01-Preview.avi
Hey Dapeter , yeah thats a nice an easy solution, sort of :slight_smile: I have done some tests and it is going to work but somehow Im going to have to animate them and I think the solution is going to be a single wave with multiple displacements in the stack so I can have them appear and then peak etc. Ill post an example when I have something useable
The snag with this Dellis whilst its an elegant solution is that it still depends on ‘wave’ and I cant get enough space between the wave peaks to make it work. However I can see another use for the concept :slight_smile:
Thanks to the the both of you
Try putting a FFD mod with the same number of lattice points as the number of waves…then you can adjust them in sub-object mode to the wave locations…then you can push and pull the waves to whatever distance apart you like while maintaing the animation stack below. Oh and if you use the material that i assigned(might be too simple)…put an unwrap uvw map mod under the FFD mod to lock the texture to the surface.
Hope this gets you there…
