Wavy textures on objects
I am new to C4D and Corona renderer and would appreciate the help of this community. I have attached reference images showing these various lines flowing on the surface of objects. And in the other image, the surface is broken up into wavy segments that are colored differently. Marked with a blue marker on both images. How can I achieve this? If there is a Youtube tutorial or any hints/links that you can provide, it will be highly appreciated!
Thanks,
Arjun
Just make a bitmap with the required wavy lines, and apply to the object in the Diffuse channel of a material :smiley: See C4D UV Mapping tutorials if required, depending on the complexity of the shape (these more simple shapes will probably work with the default UVs that C4D generates by default for all primitives).
You could also try using multiple noise shaders and layer them together. Here’s an example:
Wavy texture.c4d (255 KB)
I can’t open this as this needs a Corona Physical plugin! What is that?
New material in [Corona v7 daily builds](https://forum.corona-renderer.com/ Corona Renderer 7 for Cinema 4D daily build - Changelog ).
