We don't know were is the mistakes
We are developed a TV series in HD with MAX 2009 SP1 and Vray 1.5 SP2. WE don’t know why we have a lot of problems with the render process. The still images are perfect ( more or less) but when we make the animation render, there are erratics splotches in the animation. Specially we see this in the two principal characters ( with displacement simulating hair) and in some strange places ( walls, trees with displacement) . We are 15 years working in this world of 3d and never has this problem. We try with all the configuration that you can think in vray (animation prepass, ligth cache precalculated, brute force, high preset ) but the problem follow each time different. We are disperated , and in other works the problem begin to appear.
We don’t know were is the problem, and talk with several people about this. but any have this configuration ( Richard Rosenman for example) . In this point we don’t know if the problem is max, vray, the conjuntion , the version,or our work. The last work that we begin have the same problem, but in this case the principal model is not developed for us, is for a external enterprise, and in this case the are not sure if the problem maybe the modeling, but for the TV series all is developed here.
I can put some examples, but normally the compresion in the videos made that the problem is not visible, the the videos are very large. We think in go back to max 9 or 2008 but is very difficult and we have a lot of preproduction made in max 2009.
What maybe the solution? SP3? Maybe a problem of VRAY ( a think no but yes for the union max2009 vray sp2) ? You can see works more technical in without any problem.In some forums I see certain people that have similar problems with the same configuration ( is in spanish but you can see the images) For some people i can send examples of the files, but for the confidential agreement we can put the files here.
I have a video of 46 MB of 21 second in HD were you can see the problem. I can put here?
If you can email us to vray@chaosgroup.com with at least a cropped part of your images where you have the splotches it will be helpful. Alternatively, you can upload the file somewhere and send the link (sending 46 MB through email is not going to work).
vlado
Something sounds odd.
We have been doing lots of HD stuff with max 2009 and vray 1.5sp2 and have had no issues at all.
It would be very interesting to see the problem.
Thanks for the response with this little information.
I send you the link Vlado.
Jacksc02 i see in the web that you work in architecture( excelent works) . We don’t have problems with other projects , similar to yours projects, all begin with the characters.I promise put in some place to all can see the problem when the confidential agreement left me.
Regards
we do other work other than architecture too…
Sorry, I don’t wanna say that you only make architecture,it’s only wich i can see in the first web. Good job also un clusta.com ( the thosiba advertise is amazing)
cool :slight_smile:
although I should just clarify; the advert was done by the mill, we did all the digital (web and banners).
