We hope that the two point perspective function of ENSCAPE can synchronize with SU.
Hey @tas_1985 , so you’d like to activate our “Architectural Two-Point Perspective” as well as our “Synchronize Views” functionality at the same time?
Afterward, would you like the view of Enscape to be synchronized with SketchUp when moving in Enscape itself, or would you like to navigate around in SketchUp and synchronize that output with Enscape, just like already possible when “Architectural Two-Point Perspective” is deactivated?
The idea is to be able to overlay SKETCHUP single-line graphs onto ENSCAPE rendering graphs using Photoshop software, provided that the two software views match perfectly.
Hey @tas_1985 , please allow me to insert a detailed description from one of our developers which has been posted in this thread, which you may want to check out as well for further information regarding this subject:
- When navigating in SketchUp without Two-Point Perspective, Enscape displays the same region, with correct eye, direction and horizontal field of view. The aspect ratio of the viewport is not synchronized, therefore Enscape often has too much or too less image in the top and bottom regions.
- When enabling Two-Point Perspective in SketchUp, Enscape behaves very similar to point 1). No complaints except the unsynchronized height.
- When panning & zooming in Two-Point Perspective in SketchUp, Enscape does not pick up the changes. Therefore the perspective is correct, but the borders of the image might be completely wrong. If you think you have this problem you can check in the Ruby Console. “Sketchup.active_model.active_view.camera.center_2d” has a non-zero value and/or “Sketchup.active_model.active_view.camera.scale_2d” has a non-one value.
- When setting an explicit aspect ratio (possible through various other extensions), the behaviour is likely not what one expects. If you have black bars left/right, Enscape nonetheless displays the width of the whole viewport (including the black bars). If you have black bars top/bottom, Enscape displays an incorrect field of view.
- When rotating in SketchUp until the up-vector points down, the camera in Enscape does not follow this movement, the up-vector points up.
In any case, your wish is a topic on our agenda which just received a further upvote.
thank you very much
