I was trying out caustics yesterday and left a test image to render overnight. This morning after 1034 passes The image looks clean but in the caustic pass there is strange pixelated effect going on.
I attached couple of screenshots and passes from the render if that helps.
Would you be able to send over your scene so we can investigate?
Thanks,
Rowan
I archived the file. It can be downloaded from google drive:
My computer specs are:
i9-9900k 3.6 GHz
64 GB ram
GeForce RTX 2080
Windows 10 64 bit
I forgot to ask the golden questions.. Which versions of Max and Corona are you using?
Thanks,
Rowan
3ds Max 2019.3 Update
Corona version 5
We can reproduce this behaviour here, I will speak with the dev team to find out what is causing this.
Thanks,
Rowan
(Internal ID=445724907)
Thanks a lot!
It looks like this was caused by some caustics optimisations.
We have a workaround for this now. For the time being you can disable the “Caustics Adaptivity” checkbox in the advanced caustics settings. We will carry on looking into this and try to find a more permenant solution.
This in present in the v6 DB from 2020-06-18 onwards.
Thanks,
Rowan
P.S. you need to enable the development / experimental stuff rollout first - https://coronarenderer.freshdesk.com/support/solutions/articles/12000021288
fixed with v10 caustics improvements
