I’m facing a weird problem since we switched to 3dsmax2018 (update 4), on Windows 7. I use . as decimal separator instead of , - it’s set in Windows regional settings, everything’s ok. I have two 3dsmax shortcuts with custom maxstart files: one to run it with VRay (3.60.04) , one to run it with Corona (1.7.2). With VRay, 3dsmax keeps on using , as decimal separator, whereas with Corona it works perfectly, using . as decimal separator … crazy.
Already reported to Autodesk, but no news so far, so I try here since I’m not sure at all what’s causing this.
What do you mean “shortcut command line” ? I use -i 3dsmax_corona.ini added to the 3dsmax shortcut on my desktop to run 3dsmax with a custom Corona maxstart. Is that what you were asking ? no particular trick to run 3dsmax with VRay, it’s our standard setup.
We use Windows 7 Professionnal SP1 (x64).
