I just upgraded to 3.40 and the issues still persists. The material on the 2nd image with the reflection issue has normal bump applied. I tried both 3dmax and vray normal textures. The first screenshot has no normal/bump involved.
Then I will need a scene to check if it’s a bug or if there’s a workaround, if you can attach just that portion of the scene or send it to support@chaosgroup.com we’ll check what’s going on.
Before we do that, is there a way to get an earlier version of VRay? The same scene used to be fine on an older version (unfortunately I don’t remember which one) but it also was a different computer so I want to give it a shot.
Yes, you can download the previous version somewhere in the downloads folder. But I have run into the same problem the other day and I just did a workaround and I forgot about it. Vlado, I’m going to see if I can reproduce the issue I had and send it to you guys and take a look at it.
