Weird rendering & cam bug
Hi guys,
I downloaded Corona V3 and installed as a demo. I’m on C4d r17 prime, Win10.
I’m trying it on a new scene I’m starting and i’m having some problems:
  1. When changing cam settings (iso ect.) the ipr shows the rendering exactly the same instead of brighter\darker.
  2. When the ipr starts rendering the first passes looks grainy, like it should, and than it convert to a weird look like i’m using an old IR\LC method from vray - lots of splotches…
All settings for corona sky\sun\camera are at default.
Peace,
Kobi
Hi there, this is not a bug, it’s the fast preview denoising kicking in :wink: You can disable it here:
Thanks…
Any idea why the camera settings doesn’t effect the brightness of the render ?
In the Corona render settings and in the camera section, make sure that “use photographic exposure” is checked. Now when you run the IR you can adjust the camera’s ISO, f-stop etc. https://streamable.com/2igcn
Thanks again…
You’re welcome!
