HI,I’m testing 2.8 p1 earlier, i found out that there are some unwanted shadows appears on the ceiling,
but the same scene goes well on single picture mode.can anyone point me out the solution? thanks
Weird shadows cast on the ceiling when rendering video.
Thanks for your post @whiteanne77 , do you also see this in the actual video itself after it has been rendered?
Would be great to have a look at that video (and how bad it is) if you could maybe upload it somewhere? YouTube for example? Thank you in advance!
https://www.youtube.com/watch?v=Wa66bpPv_w8&feature=youtu.be
here is the result video,weird shadows cast from around 0:04 on the ceiling,i have try another hdri map , higher the expoture, ad some additional lights , but it still there.
Thank you so very much, it’s listed as private I’m afraid, could you also briefly set it to “Unlisted” and send in the link again? Also, this behavior may be normal due to technical reasons, depending how bad it is on the video itself, would gladly have a look at that just to make sure.
