Hi there,
Does anyone know why I cannot weld some vertices in max 9. I have units at mm’s and have overcome this problem before by creating a brand new spline and then attaching the problematic one..but this wont even work.
Any ideas ??
Cheers
Steve
Hi there,
Any ideas ??
Cheers
Steve
Mesh:
Double faces, edges
Spline:
extra segments
If your object is an editable poly object, some reasons for not being able to weld are:
double faces/edges/
or your vertices do not share an edge
(#s are Vertices), this ascii art illustrates 2 tris/1 quad, dashes are edges
1-------2
3-------4
Vertices 1 and 4 will not weld because they do not share a common edge, neither will 2 and 3
Re: Welding vertices in max 9
just to clarify… you did say spline right?
