Wet surface material observation, to be used as a ground plane under a car
Try inverting bumpmap for puddles. It probably might give a little more depth to it. Now there is a feeling that puddles are located in the high and flat parts of the surface also there is wierd tilig seam observable. I would recomend maximaly procedural material if you are going to use it on a surface wich is larger than 5x5 m
Thanks Blackbell for your comment.
I have fixed the seam you noticed, i do like the shallow puddles of water however and deliberately did not add inverted bump map.
Thanks again
Rob
