Is this feature not working in 3.3.1. I get the wet areas, my puddle are black, and no animated drops showing up.
Can you show us an image with and without the wetting ?
The puddles are basically mirrors, so they need something to reflect.
There are no animated surface drops - the ripples are the ones that are animated.
As for the drops, they need a “smooth” material to show up - there are bunch of heuristics primarily based on the material glossiness, reflection, refraction, etc that decide this.
The left one looks as expected. I guess in the middle one you set the diffuse multiplier to 0 maybe ?
I’m seeing the same issue on 3.3.1. The wet areas show up, but the puddles are completely black and I don’t get any of the animated raindrops. Is there a setting or fix that needs to be enabled for the rain effects to work properly?
Can you send a vrscene + vantage file to our support so we can check out why the puddles are black ?
