What can Arnold do that VRay cant?
is isolated selected similar to hooking up the hypershade solo mode?
No, they are different. You get shading effect of solo-ed node in Hypershade on preset geometry (like teapot etc. that are provided by Maya) whereas the isolate selected mentioned here is something like in this video (starting 10:42). https://youtu.be/4RIiMRgNpB4?t=10m40s where you get to visualize the shading effect of a selected node and ONLY the shading effect up to that node in the shading tree directly on the shaded object that has the end shading node assigned to. It really helps when you dial in texture patterns, check a specific spec lobe without mixing other shading effects that come from other sub-trees of the shading network. With responsive IPR, it really facilitates look-dev process or helps figure out efficiently what when wrong in the shading tree.
ignore this… :slight_smile:
