What can I use to ROTATE 720p video footage 90 degrees?
Hi all
I have 720p HD mp4 video footage including sound that I want to rotate. So I want to end up with 720X1280 instead of 1280X720. What can I use for this? I don’t see anything in AE or Premiere that can do this, or I’m just looking in the wrong place.
they must be able to, but virtualdub can definitely do it - just add a rotate filter
unless I’m not getting what you’re asking, AE can of course do that. you’ll have to rotate the layer and change the comp size, if you created it from the footage.
thanks I’ll try with virtualdub, is it as simple as “filter > add filter > rotate 90” ?
ae>transfer selected>rotate in viewport? I havent used it for months so I could be wrong..
thanks for all the tips
VirtualDub did the trick thanks (pretty quick and easy)
