What happend here - szene blurred
Hi, what is here the problem… No DOF, no animation, no motion blur - please helb me. A “normal” szene, but it is blurred. The denoiser is on. The camera-setting is standard, only the focal length is 28 mm, not 36. I’m desperate!
Please help me! LG Harry
Are you using lens effects?
No lens effects… :frowning: It is “funny” - the rendering is starting and become clear - but it became blurred more and more… In 1 hour it is horrible!
Have you checked the Camera Overrides in the render settings?
Standard-settings, yes… :frowning:
looks like the camara is behind a glas panel with refraction.
I have a lot of polys - maybe vray had a problem with it? Don’t know, what else… Vray-Fur - is the grass material. I will render step by step - maybe I find the problem. If I have no objekts inside the szene, it works fine.
Hello @HarrySeidl ,
Can you send us the scene so we can have a look? You can open a support ticket via our contact form and attach it there. Make sure to mention this forum thread. Also, please share some additional details, such as the exact versions of V-Ray and Cinema4d, OS, etc. Are you rendering with V-Ray or V-Ray GPU? Thanks.
Hi Harry, I had the same problem! (Mine was also a complex scene with a lot polys.) I have tried everything but nothing. Probably a bug and not a wrong setting…The only solution I figured out was switch to the Vray GPU engine…
@aleksander.kasabov - i try it out, ok - thanks! First I will have a look at tilt and shift - I did it at the settings of cinema, not vray. Let you know, if it works!
@aleksandar.kasabov - so I did it - szene is loading up… Hope you can solve it! :slight_smile:
I’ve just experienced the same behavior, after lot of render on the same scene suddenly I’ve got this:
The image was fine until I stop the progressive render.
Looks like I’m not able to reproduce the issue, if it happens again I can send the scene.
Interesting - I have material ID’s - they are clear. I opend Pandoras box!
