What happened to edit poly?
Max9 x64 sp2 ext 1
After taking the weekend off, now my 3ds max suddenly
won’t let me convert to editable poly! Usually, I can convert just about anything to en editable poly, but now, it doesn’t even show up in the quad menu. (only shows convert to mesh or patch.) Also, it does not show up in the modifier list. The only thing that allows me to do this now, is to choose Turn to poly from the Modifiers/conversion pulldown menu…Could I have pressed some damned hot-key by mistake or something? Well, thanks for reading, I’ll keep trying to get max behaving like it used to! :x
Thanks :slight_smile:
all better
Well, no “good answer” but iafter a restart/windows update, things are working normally. thanks
