What happened to textures?
Somehow on the way, textures have been behaving differently inside material editor. Now all materials have their textures relocated and renamed in a folder, which means the original ones no longer are used. What is happening here? WE all have named and structured folders for textures. While working with teams, these are shared and equal to everyone. Are WE doing something wrong? No way this is the way now… So what if I want to edit the texture, where do I go, what should I do? So many what ifs?
tex_???.jpg what is this automated duplication and naming?
This is an intended situation and expected behavior for use of Enscape with Archicad to avoid AC producing warnings to the user about duplicate file names.
Enscape assigns unique names and duplicates database texture entries to avoid conflict warnings in the Library Manager of Archicad for cases in which a material or texture changed in Enscape would otherwise use the same name and overwrite any changes of original data.
This also has a positive effect on Teamwork files. Without duplication (and reserving libraries), two users might be changing the same material and the subsequent sync might cause material/texture issues due to the same name being used. Changes done by user 1 might silently be overwritten by user 2.
If you find that the size of the Embedded Library becomes too big with old duplicates from already deleted materials, you can open the Library Manager in AC, go to the Emebdded Tab and delete unused images. Purging the file regularly is a good way to get rid of excess files in AC anyway (as usual). I found that performing this multiple times in a row is a good idea to bring the file size down since only one or two rounds of purging can leave some files remaining that are not needed. Deleting old and unused files should normally be fine, but deleting the current texture will result in it getting removed from the material and become a plain color as result.
Hi Daniel, thanks for your quick reply!
In my opinion, duplicating data is not the way. Centralizing info is crucial and leads to total integration of projects. Buildings are complex and tremendously intricate to model and generate digitally. Textures are just a drop of water in an ocean of BIM data. Solo BIM users should not even have an issue here as everything is dependent on one person only, and Teamwork from AC is exactly that; you need to reserve data to edit it. Materials, or surfaces, should be the same. Access to it on a TW project should only be for that person that has reserved it.
Embedded library in AC needs to be avoided and only to be used temporarily until that data makes sense to go on a project library or company/studio library. A template file should not have textures or any other data embedded, and purging it is a procedure that lacks data structure and organization. WE cannot design a BIM project of an airport with duplication of textures and embedded images; sorry, but this will be a problem for all BIM users. Is this the same procedure for REVIT? It cannot be…
Is Enscape keeping this duplication and embedded philosophy, or are WE transitioning to a better way of dealing with textures and trying to resolve issues in AC at the moment?
It’s funny how one embedded texture can size more than all the geometry assets (with loads of textures) from Cosmos for that same project.
Looking forward to your reply,
Cheers
It’s better to keep working with materials as it was before: changing the image in Enscape shouldn’t affect the materials inside Archicad. Only when you need to import from the Enscape material library is a new material added to AC.
Are some of the issues I mentioned resolved on the new 4.22? Like the loading all textures from the file?
Cheers
Your questions and ideas have been and will be further discussed in different departments. Sorry for the delay, some other issues required our full attention at this point in time. I will share information about this once it has been discussed further and corresponding information has been made available to me. Thank you for your patience.
I’m having the same problem with SketchUp now. Enscape 4.22 is duplicating textures and saving them in my local app/roaming temp folder, instead of using the original file location. This only happens with the albedo texture, not with normal or roughness textures.
Original file location (network drive):
J:\26-81005-00_Sorenson On-Call Services\Design\05 Design Process\03 Revit\families\GRID FAMILIES\Amico-Architectural-Revit Supplementary
New converted location:
C:\Users\user\AppData\Local\Temp\Enscape\ConvertedTextures\3f4702a6-db4b-43f4-8985-8a3293a23e74
Could you please look into this? I don’t remember this happening in the previous version.
Here’s how I have the shared texture folder set up in the material editor.
K:\_SGH_DESIGN TEMPLATE\_SGH_ MATERIAL ENSCAPE SKETCHUP LIBRARY\SGH TEXTURES\ENSCAPE SHARE
The previous version of Enscape kept the same folder. I also tested this on another computer with a different user, and it showed the network path for albedo textures.
It’s a bit frustrating. The Enscape team has fixed and improved some features, but I hope they can make sure that functions that worked well before continue to work in the new release.
Hey @dario_dimauro
thank you for describing your observations.
Enscape creating local copies of texture files into “temp” folders is generally expected behavior. This folder might become big after a while but there are explanations for this and a way to eliminate obsolete data and regain that disk space.
Enscape needs fast access to textures while rendering. Local copies of tetxures in the temp folder help avoid delays especially when original files are stored on network drives, cloud storage or slower disks.
CAD host apps handle textures differently. Local copies help the Enscape render process access these files in a consistent and relaible way.
Maybe mor of an edge case but Enscape Standalones extract textures into temporary folders so they can run without needing access to the original project files.
If you have the impression that the temp folder becomes unwillingly large over time, especially when working with larger projects, you can remove old cached files when Enscape and your CAD application are completely closed. Depending on your Enscape version, relevant folders may include:
C:\Users%username%\AppData\Roaming\Enscape\Data\Textures\
C:\Users%username%\AppData\Local\Temp\Enscape\SketchupTextures\
and other folders you might be using for temporary files as you have stated.
You can just delete the content of those two folder and the data will be recreated with new files when need be.
It’s also worth keeping your original textures in a well-organized project or company library, prefrably using consistent file paths.
I hope this information is helpful.
Hi again Daniel,
Would it be possible to use a local texture library—such as an internal SSD drive or a similar storage location—with Enscape in Archicad, using textures curated by our team?
Our texture folder is already organised, not specifically for Enscape, but because we use these assets across other software for presentations and similar purposes. It would therefore be very useful if Enscape allowed us to select an existing local folder as its texture library.
Most comparable solutions offer this type of workflow, so having the option to point Enscape directly to our organised local library would greatly improve our process.
Thank you for your help.
arq. João Mourão | +351 962 404 706 | joaomourao@gmail.com
Graphisoft Certified ArchiCAD Expert | Graphisoft Registered Consultant
building SMART international | profissional certification: Foundation
@joo_mouro Enscape does not itself offer the functionality of creating and/or managing your own texture library.
Nevertheless, I see the following options for you:
  1. create an embeddedd library in Archicad that holds all your textures.
  2. create a sample project file that holds geometry with the selection of your textures, maybe different project files for different content areas of textures
  3. create the textures in Enscape. Once finalized, use the material editor of Enscape to export a matpkg file for each material. Store and sort them in your own manual texture folder structure. Once you need them, you can batch import a number of matpkg files into the project file again in one go.
I hope that this information is useful to you.
