What has happened to Chaos tutorials?
This is what I see if I try to open Chaos tutorial in Max Phoenix menu.
Things used to be a bit different. These tutorials don’t require special configuration to be viewed.
Dear @JuhaHo , hello.
The issue has been identified and should be solved out now.
Please bear in mind that some video previews may be missing (error 153), but the videos are opening fine in YouTube, if you click over the hyperlink.
Could you please confirm?
https://documentation.chaos.com/space/PHX4MAX
If a special link is missed, please point it out.
Best,
TS
Thanks,
I just tested, but can’t see any change on behavior.
Hi again,
You have also an opened ticket regarding the topic.
Our docs team proposed the following to try, since it could be related to browser:>
  • Clear the browser cache: A corrupted cache can prevent images from loading.
  • Disable browser extensions: Some extensions—particularly ad-blockers or network-related ones—may block content. Try temporarily disabling them or test in a different browser.
  • Check network security tools: Your company’s security tools might be blocking the domain Chaos Docs . If possible, ask your IT department to review this and add the domain to their approved list.
  • Test on another device or browser: This will help determine whether the issue is specific to his setup or a broader problem with the page. - as far as I understood you are able to see the content from a different device
  • Check the video file format: The browser may have restrictions related to playing YouTube videos. - on your screenshot you are missing images, not videos, but please be aware of that
We could offer to send you the offline documentation if none of the above mentioned steps works.
What do you think?
Best,
TS
Thanks for Your answer,
I have one man business. All I know Chaos help/tutorials stopped working in all my workstations after I installed the latest Windows 11 25H2 build.
Now I see this, when trying to open Chaos tutorials.
Cloud Flare is down and all stuff with it. Like Twitter.
For me Twitter seems to work, however in some posts external media is blank.
Yes, it was global CloudFlare outage, but it should be fine now.
Here is the archived offline version of Phoenix for 3ds Max docs :: Archived Version
I still don’t see the tutorials. Is there any development on this?
I have sent you the offline docs in my previous post.
This is a bit funny. I downloaded the Tutorials linked above. On there I can see images, but no videos. When I open tutorials from Max I can’t see images, but I see videos. So to use the tutorials I need to have two instances opened one for the images and one for the videos.
As far as I understood, this is happening for you on one machine only.
Videos and images are displayed now fine, we tested the visibility.
Please take a look again at the advices from our docs team shared earlier.
Thanks,
Clearing a browser cache didn’t change anything.
All browser extensions have been disabled already
I have one man business. My workstation is connected with 5G modem. We don’t have other choice in this building since the copper wire was disconnected.
I haven’t installed any browsers to my main workstation except Edge that was preinstalled. Anyway tutorials don’t work in my secondary workstation nether with Edge but work fine with Chrome.
The problem with Chaos tutorials started when I installed Windows 11. I would expect Chaos tutorials to work with a standard WIndows workstation.
Thanks for the details.
So, you do have a working browser, but you don’t want to install Chrome on the main workstation. Am I correct?
Have you seen is Edge up to date? I tested with it after update to Windows 11 and I am seeing the images.
And about the offline tutorials, you are not quite right. Videos are there as hyperlinks, so you are able to open them in YouTube.
And images are applied in the text, so everything is there.
Thanks,
I want to install minimum amount of software to my 3D-workstation.And Yes, Edge was up to date. I noticed, the Cosmos Browser and material browser were not working either, Otherways Edge seems to be working correctly.
Google ‘How to flush dns’ and try that.
Chaos Cosmos & material browser issues - some processes or addresses could be blocked, but this needs to be examined by our Tech Support team.
I found a lot of threads at different Microsoft forums about missing images (but visible in other browsers).
Some of them were related to the location.
This looks like an everlasting thing which happens from time to time to different users.
It may be worthy trying there: https://learn.microsoft.com/en-us/answers/tags/781/microsoft-edge
They mentioned also about disabling extensions and reinstalling Edge, but this is not related to Chaos.
Keep us posted.
