So… as we’re taught in rendering to never use max RGB values (ie; pure white should be somewhere around 200, 200, 200 value, max!) what is the best way to ensure I accurately represent real-life colours in renders? สมัครdewabet
I have an interior scene where I’m demonstrating varied wall colours. For example; the paint product “Tikkurila Symphony - F487”, has an RGB value of 228 226 218. Obviously it’s advised to not use these high values. So, what’s the best method to ‘downplay’ (for lack of a better expression) these values to then accurately represent this colour?
Honestly, when a client wants “perfect” color representation I usually try to get it as close as possible in the VFB and then I do slight tweaks in post. Its rarely 100% the same as the RGB they want because obviously lighting plays a role.
That being said, I would also recommend to use a fairly neutral tonemapping / LUT adjustment. Sometimes the colors can get really weird if you use some weirdly aggressive LUT.
Good luck. Personally, I usually think ‘close enough is good enough’, as it does change so so much with various lighting, tonemapping, LUT’s etc… even different devices show colour dramatically differently, and sometimes it’s all down to subjectivity.
