I have a scene that I am rendering at the moment… I have a dual 2000+ athlon workstation that renders the scene very quickly but if I use net render to send the scene to a slave dual 2400+ athlon, the processors on the 2400+ only run at between 4% - 8% :evil:
Obviously this takes forever to render the file! Any ideas?
After a bit of testing this doesn’t seem to be a problem with backburner after all :? I have loaded the file on all 4 machines and only my main workstation will render it using 100% of the processors… the others sit at between 4 - 10%
The only reason I can think of is excessive disk swapping… check the memory usage on those machines. Do they have less RAM than your workstation? If yes, and if rendering requires more RAM than is physically present, Windows will use the disk for additional storage, which decreases performance drastically.
Well I am not running out of memory, but the red led on the front of the case for the hard harddisks are going crazy!That’s the point… for some reason, Max or Windows needs to access the disk, which is what makes the rendering so slow. Do you have any textures? Lots of geometry?
Just one texture and not a lot of geometry… it is just a cut away section of a stair case. I have just made a test file (A plane, spere and skylight) It renders fine on the main workstation, renders just as fast on the other workstations with 100% processors this time but the shaddows are seriously messed up on the slave machines.
I had the Max 6 version of vray on my workstation for a while now but just downloaded and installed it on the slaves today. Could there be something wrong with the files I downloaded today?
Shadow problem solved - I dont have Vray authorised on the slave machines so I take it you can only render to these slaves through backburner to get correct results?
Still have the same problem with the stair file rendering rrrrrrreeeeeeeaaaalllyyy slow on the slaves
As you can see there seems to be a problem with Vray for Max 6 that is not present in the Max 5 version Can you please take a look at it Vlado? Give me a shout if you want me to e-mail the file.
that looks like for some reason that the max6 setup is using more ram which ties in with the 4gb Ram setup being the same and the lower processor % on the 2gb…looks like its using swap…why, i dont know.
