Hi there im a complete noob searching for what is HDRI and HOW to use it? please anyone help out ![]()
There’s a good explanation at http://www.trinisica.com
Toby
Can’t see the image!!
hdri explanations
Standard bitmap file store the informations for each layers (red, green, blue) between 0 and 255. That means that white is equal to 255,255,255.
So, in a photo, the sun would appear as white, a lamp bulb also, a piece of white paper also… But their real intensity are differents.
Hdri file enables the storages of the real instensite of each pixel (a sun could be 1000 times more lightning than a lamp bulb…).
Moreover, hdri files are often panoramic representative, (cylindrical, sphérical, cubical…)
What can you do with hdri ?
1) Use them to create true reflection
2) Use them to illuminate you scene
3) both 1) and 2)
How to 3)?
In 3dsmax, in the material panel assign in any map chanel a VrayHDRI then load your hdri and choose the right type (look for kitchen_probe.hdr on google and choose angular type), the in the environemment panel (8 key) grad and drop your VrayHDRI.
Then in the render panel, choose vray, check global illumination and that’all (for the first step create a metal sphere on a plane for instance)
Click render ![]()
Sorry for the bad english
is there any other way cuz I dont see the VrayHDRI just VRAY MAP
see->
oooo, I can answer this one… I think you have VRay Free. You need to download the Splutterfish HDRI loader plugin.
Look here: http://www.splutterfish.com/
This will allow you to use hdri files in max. Beyond that, can’t really help you yet. (still trying to figure that out) but check out the help file that comes with plugin. Hope this helps.
~pog
