What is the 'correct' method for deriving vertical field of view?
So I’ve found three different ways to derive the vertical FOV (field of view) from the horizontal FOV, and each method gives me a slightly different number. So what I want to know, is which one is the correct method?
vFov1 = 2.0 * atan(tan($cam_render.fov / 2.0) / GetRendImageAspect())
vFov2 = atan(tan($cam_render.fov) * ((renderHeight as float) / renderWidth))
vFov3 = ($cam_render.fov / GetRendImageAspect())
So, if I have a 70mm camera, using a 36mm film back, and a resolution of ‘1920x803’, the resulting values for each of the above are:
vFov1 = 12.2765
vFov2 = 12.9701
vFov3 = 12.0624
