What is the current Displacement status?
Hello, I tried using the search tool, but it’s very limited in functionality (filtering particular subforums), thus posting this here.
Could anyone share what the current status of the displacement is? I mean a situation where multiple sub-objects could have different displacement maps, or have better control with Forest Pack / Proxies?
After an initial scan, I see that something is in the works for Maya / Cinema / Sketchup versions → I presume this might affect 3ds Max too?
An ideal solution would be to have the same set of controls that the modifier has in the material tab?
Could anyone share some info regarding this? Thanks in advance, and sorry if that was mentioned somewhere already.
The general solution for multi/sub-materials is still to use VRayDisplacement’s “Use Object Material” option.
Yes, there is work being done on implementing a displacement shader (in Maya, for example); however, I’m unsure if it will affect 3ds Max.
There’s a similar idea already submitted in the Portal - vote for it.
Meanwhile the vote..
“Created on Sep 2, 2024”
You just need to vote more /s.
