What is the deal with BerconMetaballs?
I’m pretty sure it’s ‘thinking particles’
http://www.cebasstation.com/index.php?pid=product&prd\_id=109&feature=1052
Just installed the 2011 x64 plugin for VRay 2.0 - getting an error when loading the plugin on max startup.
I have installed the Microsoft Visual C++ 2005 Service Pack 1 package (mentioned in another Bercon Metaball thread) from here: http://www.microsoft.com/downloads/en/details.aspx?displaylang=en&FamilyID=766a6af7-ec73-40ff-b072-9112bab119c2
..to no avail.
Any other package I need to install?
Am I the only one who can’t get it to work in 2011 x64? Would be nice to be able to play with this between christmas and new years - my annual 3d playground time. :slight_smile:
Hi Henrik, I can only tell you that it is working fine here - don’t know what you might be missing… Any chance that you can try it out on a second PC and compare which updates you have installed?
God Jul!
+1 Quoted for awesomeness.
Just tried on a laptop. Win7 x64, max 2011 x64 with latest service pack + hotfix, latest vray 2.0 build and Bercon Metaball 2011 x64.
Same error message: “failed to initialize. Error code 126 - The specified module could not be found.”
My workstation has VisualStudio Redist. 2005, 2008 and 2010.
Laptop has 2005 and 2008.
All in both x86 and x64.
Stebbing3D: I lige måde. :slight_smile:
Where did you put the files?
Hah - Now I feel like a proper idiot. :slight_smile:
I had just clumped it in with Berconmaps in the plugins folder root. Didn’t realize it had to be relative to other vray dl* file(s).
Thanks!
Ah, ok :slight_smile:
Just as an aside Vlado I’ve noticed that this doesn’t work with the vray velocity pass - it just outputs a green value!
Could we have a Bercon Metaball recompile for Max 2012?
And also is there any news on that exciting Bercon Iso/Distance Tex shader that was mentioned a while back?
Martin
And BerconMaps?? :slight_smile:
I know Jerry is working on the maps but a bit snowed under otherwise, so not quite sure how long it will take.
Not sure about the Balls though…
Here is bercon maps for 2012 link
http://www.maxplugins.de/r2012\_files/jerry/BerconMaps\_3.01\_Max2012.zip
Didn’t vlado compile the last version of metaballs for vray 2. Maybe he can do the 2012 version?
Great stuff… Thanks.
Yep, will compile this one for V-Ray 2.0 as well.
You can get the recompiles for 3ds Max 2012 here: Chaos: Industry-leading design and visualization software
Thanks a lot Vlado, that’s great!
Great! :slight_smile:
How about the Iso surface plugin - with mapping capability? *wish* :smile:
Everything seems to be working fine except the MetaBallsTextures. Here, it crashes max when I open the slate material editor.
