what is the script name for IR in extended viewport?
hi guys, these days trying on basic max script learning ;). I want to make a button to activate IR in extended viewport but I don’t know what is the script name for IR in extendedviewport.
Here you go: Chaos Corona - Global Site
thanx romullus :), I know CoronaRenderer.CoronaFp.startinteractivedocked but what I mean is set the viewport to extended viewport with IR.
sorry for wrong explanation before.
cheers!
For that you should refer to maxscript help: Help
However it looks like that particular extended viewport isn’t accesible via maxscript (i can be wrong, though). Personally i’ve assigned shortcut to extended viewport #3 (Corona interactive) via customize user interface. So now, when i need IR, i hover mouse over prefered viewport, press F11 (my shortcut for extended viewport #3) and then click on that viewport to activate IR. It’s good enough for me, but i’m sure, someone much smarter than me, will show you even more convenient method ;]
sorry for late reply,
yes romullus, I was right in there in viewpanelmanager to set extendedview.
what I mean is I can set the viewport 1 to extended VP trackview with
ViewPanelManager.SetExtendedView 2 #ev_type_tree
but I don’t know how to set my viewport to extended VP coronaIR.
cheers & thanx
for ondra, if it is necessary could you please add the maxscript name for IR in extended?
I would love to, but… max api :frowning:
so max API limits that cool things…,
ok thanx & cheers :smiley:
