This error appear when i open cxr file
As far as I know this happens when you move, delete, rename the image from history folder and tried to reload it, but one time it appeared even when I didnt make any change, closing max or reopen the image into history solved the issue in my case,
If this is your case have you tried opening the image into CIE?
Could you please try the following?
Check that the CXR file exists in its original folder and is not 0 KB.
Try opening it directly in Corona Image Editor.
Try opening another CXR file to see if the same error occurs.
Also, are you opening the file from VFB History or directly from the folder?
If the issue continues, please submit a support ticket here so we can investigate further:
https://support.chaos.com/hc/en-us/requests/new
Please attach the affected CXR file when submitting the ticket.
