What is whit my floor
I do not know what happened to my floor .. please help: (
Re: What is whit my floor
wow, interesting effect :o
Maybe you have a procedural effect in your floor material that is not set to the UVWGenChannel. What are your material settings?
you have to post your material and tell us what you’ve done so we can help :smile:
m:
http://resources.maxwellrender.com/search.php#page=1&mode=1&id=5393&search=dirty floor&v1=0&v2=0&tipo= <-- material - dirty floor from maxwell
m settings:
What are your bump map and displacement map settings? Also, if you have both turned on, renders can sometimes have problems.
I tried to turn off bump mapping and disp … I tried to disable the reflection, even a map the floor in another file and there does not repeat the problem: / I have already finished ideas
