What the hell is this???
This is an error message that appears when I try to render my scene.
:shock: I’m shocked!
if the image is not showed above…
try this: http://www.fabriciomicheli.freeservers.com/error\_vray.gif
Now it works!
i think that is something you should sent to Vlado at chaos…
Natty
yeah I’m getting the same think and I sent my text file in …like …2 times…
so I just installed the latest version of the v ray went back to g …
some times its bad whoohaa..in the geometry ..read the text file…
Here’s part of the VRAY log file.
In a line, MULTITHREADS are aborted by the renderer.
I don’t know about that, but maybe it’s something there…
why cant you be a little polite???
edit your message and change the topic to something normal.
:evil:
wow taboo, i’d say his response is legit.
for one, the word hell is barely a curse word, i suppose he could have said, “what the hades is this???” to be more polite, but who’s being semantic.
i’m personally suprised at the numerous spelling errors in the error log.
That could be any number of Errors. The first thing I would ask you is if you are using Dreamscape or are running low on RAM, the only two times I ever see that error are in those instances.
fabrizzzio: most likely it’s a memory issue, maybe you have too much geometry in the scene.
Hi…
Vlado Im also getting this error and I notified u about it, u even said that i should send a sample of my scene a while back which i did, but never got a reply…it always happens (at least with me) when i have Dscape and Vray in a scene, with Vray as the renderer for the Meditor and i want to edit my materials in the Meditor.
A workaround (which i honestly dont think its a workaround but at least u get rid of the errors) is to use sacnline in the Meditor but Vray in the render…but when i do this i cant see my Vraymtls in the Meditor.
How can I fix this? :sweat_smile:
