What's the difference between origRGB and RGB_color?
I get two similar-looking renderelements from Vray:
What is the difference?
When I uncheck “Save RGB” I don’t get any of them.
I need always the denoiser and the original RGB but not RGB_color, which is only wasting space.
Thanks for help!
Hi the Frame Buffer Settings documentation says: > Separate render channels – Saves the channels from the VFB into separate files. Use the Browse… button to specify the file. This option is available only when rendering to a memory frame buffer. If rendering is done only to a raw image file, the render channels can be extracted from that file after rendering is complete. If the VRayDenoiser render element is enabled, the RGB channel is saved with the text origRGB appended to the filename, and the effectsResult channel has the text RGB_color appended to it.
Also if you have lens effects enabled it will save into the RGB_color
Okay, thsnks.
Strangely I either got only denoiser or both RGB
