what's wrong with these rpc?
it renders ok when i have lower vray setting or even after a max restart. anyone had this problem before? does anyone know a better way to generate shadows out of rpc? thank you
-k.kwok[/img]
use a projector map on a lite. see the website for tutorials. go to rpcnet.com
also i think you viewing angle is too high for the rpc’s to be shown correctly… :!:
i have too many trees. this is an animation, projector map is not possible. everything on the rpc.net doesn’t help. thank you anyway. just wonder if you guys had the same problem before… i got an error pop-up when rendering every 30-40 frames. and those are not hi angle at all. i think it just vray n rpc doesn’t get along with each other… anyway, thank you.
-kwok
if u hv too many trees, goto ur top view, do a screen capture to pin point the location of the trees, then draw a bitmap with shadows corresponding to the tree location, then pop in the projector map, its not gonna hurt ur rendering time alot at all. Done it many times over. I QC’ed for RPC before. There’s a tutorial to make projector maps in RPCnet, look for it.
RPC will mess up if u try changing them to VrayMtrl and copying them as instances (sometimes as a copy too), there’s a ‘RPCrepair script’ that works to correct this (but it was written for Max 3.1 many yrs ago, not sure if it will work for 5.1), but if the RPC are messed up, u probably hv to delete and replace them.
