what's wrong with vantage
when change the render size
This is probably happening because your GPU doesn’t have enough VRAM to compute the new resolution. What is your hardware and to what resolution are you setting it to?
Alexander
Have you disabled the “Safe GPU allocations” checkbox?
Yes , I had already done,but ,some zize can be rendered out and default 4k 1080P
Sure to be rendered
I think :after changed resolution ,dont click “enter”,click any other checkbox to take foucs from resolutions,sometimes the aspect locked the resolution isn’t right.
good luck
Really good image - very well designed :slight_smile:
I’m curious; where did you find the rope artwork…or did you model it yourself?
EDIT: Don’t worry, I found it :slight_smile: It is macrame, for anyone else who is interested.
