When distributed rendering in corona, the slaved computers do not update or pass.
When output size was 2500, distributed rendering was good, but it didn’t work from 4000 started.
This looks like it is to do with your slave machines not having enough RAM to cope with the higher resolution size.
You can see in the screenshot that your machines are heavily using the paging file as they have commited 40+GB of RAM when there is only 16GB of physical RAM on the system.
I would suggest rendering at a lower resolution or if possible increasing the amount of RAM on your system.
Which version of Corona are you using too? In Corona v5 there were many optimisations which may help decrease the consumption.
Thanks,
Rowan
I use Corona4 and bought a RAM and installed it.
Thank you so much.
