When moving the Interactive window to a secondary screen, 3ds Max UI gets broken
I’ve experienced this for a long time. i do not know if it is a bug in 3ds Max or a bug with corona. But if you have two monitors and move the interactive rendering to a secondary monitor, all the 3ds Max top menus, such as File dropdown, Edit dropdown etc gets offset. So essentially I cannot see the File or edit dropdown list they get offset out of the screen. The only way to get it back is to minimize 3ds max and back up again. It does not happen instalnly but If I keep going back and forth to the progressive rendering window and it is running, then at a certain point I cannot access these menus anymore.
Which version of Max, Corona, Windows etc are you using please?
Rowan
I use Windows 10 and Max 2021 with latest official corona release.
This problem has been around for me through max 2020 as well and earlier releases of corona. I think it started happening after 3ds max added HiDPI support, but I’m not sure.
