When using the Vray RTX render, the render of MotionBlur does not get caught.
// Error: line 1: V-Ray : [VUtils::VOptix::OptixPipelineWrapper::launch] 7050: OptiX error encountered in vray_optix7.cpp[314]. Error Code 7050 //
With an error, the render proceeds, and the result of the render comes out in Black. My Vray version is 5.10.22 and Nvidia version is 471.41.
Excluding VRayStochasticFlakes, the problem disappeared, but this time the texture is broken. (when I apply subdivison and motionblur)
Even if it has been resolved, I would like to know why the above error occurs.
Can you send the scene via the contact form so we can take a look? Mention me and include a link to this thread.
Thank you! I send you completely now!
This is not a same scene. But you can make that situation very easliy.
I’ll give you only sphere and one texture. And there is same issue.
Did you receive the scene that I sent you? I’ll be waiting for you!
Thank you. I managed to reproduce the issue - it happens when using both Subdivision and Motion blur on GPU. It is already logged (internal bug-tracker id: VGPU-5522). I’ll bump its priority additionally. Otherwise, you can use OpenSubdiv as a workaround instead.
Thank you so much! Unlike other renderer’s forums, it’s amazing to reflect very active feedback.
Has this problem still not been resolved? Still noticing it with Vray 5.2 in Maya 2020. A real bugger as I need the speed of RTX to render my scene and all my characters have viewport subdivision.
Not quite yet. I’ve bumped its priority additionally.
