Each new version of VRay we are curious if the error message “// Warning: V-Ray : Multiple source objects for VRayEnmesh node “VRayEnmesh1” is currently not supported!” pops up.
It takes a lot of time to assign each enmesh to each object individually when you have a large scene. Combining everything isn’t always possible.
For now we have made a workaround script where you can choose what existing enmesh you want to copy onto an object. But it would be preferable to just add the object to the Sources Set.
When will multiple sources be supported?
Thanks!
