Where are my render elements?!
when i setup a render element (e.g. vray zdepth) this element is not saved. I can see it in the VRay Framebuffer but can not find it anywhere!
Whats the trick?!
Thanks for help!
herrstock
well you need to specify output file in your vray frame buffer output, the element(s) will be saved in that directory. If you just render vray in 3ds max does not save any images, only holds them in memory. You can also enable history in the vfb and save the images that way (not recommended for sequence renders though)
Thanks for that hint, i will try that!
herrstock
