Hello.
I’m trying to render an image using DR but started as a backburner job in a single node that will then call the others to join in as DR slaves. Of course the workstation would be excluded.
I know this is possible if you set the initial node for using DR and exclude the workstation from the list.
Can this be done by directly modifying some configuration text file?
If so what file? I can’t seam to find it.
Not sure about the text file but if you need the exact file to work with just go into Back Burners job folder and copy out the job ..Unzip it… open it up and set the DR nodes and resend.
Hope this helps.
-Fizzgig
Normally V-Ray uses the vray_dr.cfg file in the plugcfg folder of 3ds Max for the list of DR render slaves. The “plugcfg” folder is stored somewhere in the current user’s profile; the exact location depends on the operating system.
