Where can i set Material ID and Object ID?
I use the Bloom effect and I want to use a Bloom mask. How can I set the Material ID and Object ID for use with the Bloom mask Material ID and Object ID?
Where can I set the value of these parameters in this?
Please help me
Object ID can be assigned by right-clicking on an object in the SketchUp viewport. See Chaos Docs for more info.
Material ID color is set in the Material Options section of each material’s settings panel - Chaos Docs.
Currently, there is no way to assign Material ID numbers manually. They are set alphabetically for each of Asset Editor’s Material list entries at the time of render. This will be improved in the next major release.
Kind regards,
Peter
Thank you :slight_smile:
