I’ve rendered an animation in the last weeks, and now I see that the frames (saved as jpg) are compressed too much. But I can not find the place where I can set the compression level of the JPG’s. V-Ray is not using the settings of Modo.
Where can I set the image format and compression level of the image format in V-Ray for Modo?
There is no way to specify this at the moment, I thought I set it to 100, so the highest quality and lowest compression.
But it seems there is a bug somewhere, so it actually defaults to 85.
I will see if I can fix this and also make it use the MODO settings from Preferences → File I/O → Image I/O.
