I just rendered this image for creating a panorama.
but something is wrong with the color…
any idea of why i get this?
IMAGE::::
SETTINGS::::
thanks!
IMAGE::::
SETTINGS::::
thanks!
Perhaps this explains a little bit more the issue…
thanks
You can try to use high presets instead ![]()
Gonçalo
mira we ponle en donde dice .9 a 1 en secondary bounces y activa direct comp y le pones depth a unos 20
y el primer difuse bounce a unos 1.5
donde dice irradiance map presents dale a very hight y leugo a custom para los artifacts =)
That looks like JPG compression artifacts, or it might be a sign of a problem with the authorization. Try to save the image as a TGA, or high quality JPG and see if the banding remains. If you still get banding you might need to contact Chaos Group to reauthorize.
