where is self-illumination settings in Vary~
Hi all,
I’m a newbie on Vary. I’m looking for Self-illumination settings in Vary. Dose anyone know where is it~?
Thanx a lot~
You can’t use self illumination on avray mat, but you can set the GI mutliplier of the object (in the system submenu of vray) at a high range which does sort of the same effects. You can also use a standard material with self ill, or use the architectural material and set a very high luminance (there was a thread about that trick some times ago, try to search the forum…)
thank you very much,suitaloon. It’s really helpful~
you can also add a “vray material wrapper” to a standard self-illuminated material, as i recon…
