Where is vray.info
Hi everyone,
Im am a new user of vray advanced and i am very impressed by its features.
I have been going through this forum a lot lately and i keep seeing links to vray.info or www.vray.info but these sites don’t seem to excist.
Does anyone know what happened to them ?
And is there a better manual file than the one that comes with vray because it is not really helping me to figure out how to use vray in a proper way.
Thanks,
Erik
I can enter the site with no problem. Double check your firewall, if you have, or your activeX configuration, since I think that there’s an activeX control for flash banners
Tanks Marina,
I checked with our administrator and it is indeed a firewall problem.
Hopefully he will fix it soon, i very much would like to make some progress with vray so i can post some work in the future.
Erik
hei erik, would you mind give me some help in this question? never more i get acess in vray.info. THE internet service provider said me that everything its ok. the net administration said that doesnt exist any firewall active. But i cant conect anyway. My SO is win xp and internet explorer 6.0. COUld you say more dectails about solution of this problem?
Ok silverioneto,
As soon as we figure out what the problem is i will try to give you more info.
But be aware that internet, firewall and network settings are not really my ballgame. So don’t be disapointed if the explanition is a little bit thin.
Erik
hi guys… i would like to say that … unfortunatelly, the problem continue here. I need so much vray.info, but at office i try averything… call to ISP, they said that only be a firewall… but i havent firewall and the firewall from windows xp isnt active. The only difference betwen here and the office is that here, at home, the internet caem from modem using phone line/ in the office the conection is from cable modem. I dont know if could be this a trick to solve problem. The guys from ISP said me also that this kind of adress www.vray.info isnt common, because doesnt have .com , so this should be another fact to examinate. So , i really would like to ask for someone from vray.info who take a look in this questions and if possible give some advice about what shouls i do :shock: because without vray.info i keep crazy :?
unfortunately for you ill post this from the mirc forum this morning:
<egz> hey guys, I’m driving to the airport in a few minutes. I’ll be back in 2 weeks or so
<egz> Be nice to yaRV while I’m gone :wink:
Hi elf
How is everything going ??
Have you been able to look into these problems already ?
I would really appreciate it. :slight_smile:
Erik
.info is an official ICANN top level domain just like .com so the excuse about it not being common is pretty stupid. Once again, the problem is probably on your ISP’s end. The site works for almost everyone else, so there is not much I can change on my end. The webhost has checked their setup and everything is fine (which is why thousands visit each month). Keep bugging your ISP.
will do,
thanks for your time.
Erik
Vray BugFix
Anyone know where i can d/l the new Vray bug fix?
Uhm, the same place you have downloaded all your previous versions maybe?
:roll:
Ok,
i have the same problem. Local network firewall dont give me access to vray.info
But, there is a chance of viewing it thru the http://www.webwarper.net
Some times it helps alot.
http://www.webwarper.net/ww/~GZ/vray.info/news.asp?\*
Hey Shurlin,
Many thanks for this, it works.
Erik
